I am running Domino Server 6.5.4 on Windows Server 2003 standalone server (not part of a MS Domain and not a Domain Controller). I have checked windows OS using “netstat -a” in command prompt and I found no single thing is listening on port 389. When I try to enable LDAP on Domino Server I got this error msg : LDAP Server: Another application is already listening on port 389. I have NO problem at all when I run my Domino on Windows 2000 platform. Anyone have any advice? I really appreciate it.
Subject: LDAP Port problem
Hi! =)
Just for laughs, try reconfiguring your Domino LDAP port to listen on 390 and see if you get the same error.
Let us know!
+Josh+
Subject: RE: LDAP Port problem
If what Josh suggests works, try a root DSE search and see if there’s another LDAP server at 389.
“Searching the root DSE and schema entry”
Hi Ken Lin,Thanks for your reply. I use port 389. Still get the same message (another application is already listening on port 389). When I use ldapsearch, here what I got:
E:>ldapsearch -h hostname -b “” -s base “(objectclass=*)”
objectclass=top
subschemasubentry=cn=schema
namingcontexts=
supportedextension=1.3.6.1.4.1.1466.20037
supportedextension=LanguageCodes
supportedsaslmechanisms=EXTERNAL
supportedldapversion=3
supportedldapversion=2
vendorname=IBM Lotus Software
vendorversion=Release 6.5.4
I think we were trap by Microsoft’s dirty trick. Make non MS product non-compatible. LOL.
Are you sure that you didn’t initially install Domino as a service, Maybe a copy of the Domino server is actually running in the background and grabbing 389 before the instance you’re starting can get ahold of it.
Hi Josh,I did change to different port (e.g 8389). It works just fine. But really want to use 389 (standard port). Thanks anyway. ![]()
