Hi all!
I'm evaluating posting Domino metrics to a hosting partner and would appreciate some advice.
The goal being to help our customers monitor their Domino server environment, improving performance and pickup on configuration issues. A solution that would assist us the administrators with graphs, incident handling and alerts in one offering.
A preferred solution, mainly for its simplicity, would be New Relic but a new offering from the HCL/Panopta partnership is being evaluated but there are considerations.
I started looking into The New Relic solution which is carrying a dated plugin, created originally by IBM I suppose. The implementation is most appealing, as before mentioned, since it implies adding only one line to Notes.ini (except for creating the account and noting your license key of course) and off you go.
However, the plugin solution not supported by New Relic and access to this plugin will not be available for new accounts. It's being deprecated and customers are urged to look into their SDK for a solution. Furthermore, you are not able to use the complete New Relic offering but are pushed into the Insights corner which narrow down your maneuverability somewhat.
Another offering of interest is the HCL / Panopta partnership which at first looked promising though I would not prefer the intrusion on the client's estate running an installed agent which in itself would imply maintenance, some overhead and on the whole perhaps unnecessary complexity.
But his would not to be. After initial success the Panopta agent on a Windows server stopped working and metrics were not being posted to the Panopta backend. The reason for this was the agent's inability to parse the json metric file output from Domino. When I confronted the Panopta support with this they blaim HCL Domino for the output not being parsable. Nothing they could do but direct me to HCL Support. Note that the instructions from Panopta on how to integrate the agent with Domino was followed to the point.
Linux file permissions was another issue. The permission on the metric files output form domino didn't allow the panopta-agent to delete the metric after processing, hence the files were not being processed at all. A workaround was needed as the domino server does not heed the directory acl.
The Hosted-Graphite offering wasn't considered because of their pricing scheme.
I didn't have any luck getting any useful support from Panopta or New Relic. Panopta claims to have confronted HCL about the parsing issue but not receiving any feedback and New Relic on the other hand don't support a third party plugin.
So where are HCL heading with the New Relic offering and are they improving on the Panopta relationship?
Any other suggestions to get a healthy monitoring systems going?
Note: Self hosting Docker images of Graphite/Carbon/Whisper and Backstop on Centos 8 (Podman) could perhaps be way forward if you are willing to put in the effort.
