Language Pack problems
On an upgraded server, from 5.0.8 to 6.5, i installed the Swedish Language Pack. After that i replaced the design to Domino Web Access, get the dialog to choose language, and then replace, all fins soo faar, but then theres no mail in the users inbox. visible is he runs through a webbrowser, but not in the client.
Example 2, as a test, installed a fresh 6.5 server, did the same Language Pack install, copied my own mailfile, and same error, no mails in the inbox, uninstalled the Language Pack, copied again, and the mails are there, bare in mind that i didnt even replaced any design here…
Whats up with this, any one else got the same problem or a solution?
Subject: Language Pack problems
Hello, I experienced this too and do not have a solution (I was just thinking : “well, nice possibility for a user that (s)he can switch the language, but - what a price to pay for an admin:“ALL MY MAILS ARE GONE !!!””)But I think it is a bug, not a feature and we should better get used to it.
