Hello all,
I have tried to add the polish language pack to 8.5.1 FP5 Domino Server but the installer finished with FATAL_ERROR. I have checked the LPlog.txt and found such lines:
Merging language components into Domino server templates…
Polish
E:\Lotus\Domino\data
bookmark.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main bookmark.ntf template. ***
discussion8.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main discussion8.ntf template. ***
doclbw7.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main doclbw7.ntf template. ***
journal6.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main journal6.ntf template. ***
mail85.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main mail85.ntf template. ***
notebook8.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main notebook8.ntf template. ***
pernames.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main pernames.ntf template. ***
resrc8.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main resrc8.ntf template. ***
teamrm7.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main teamrm7.ntf template. ***
toolbox.ntf
ERROR *** Mlmerge encountered a problem [FATAL_ERROR] while adding Polish components to main toolbox.ntf template. ***
What does it mean?
Is there anyone who can help me with this, please?
Jacek W.
