Keypress values - Help
Hello,
I am trying to print a view, but i want it to print the current view, so i am putting some kepresses in so i can select the right options, here is my code, but its not working :
Dim s As New NotesSession
Dim db As NotesDatabase
Dim uidb As NotesUIDatabase
Dim v As NotesView
Dim Nv As NotesView
Dim NDoc As NotesDocument
Dim uiv As NotesUIView
Dim strFormula As String
Dim strUCode As String
Dim strPicker As Variant
Dim strName As String
Set db = s.CurrentDatabase
Set uidb = ws.CurrentDatabase
Set v = db.GetView("PrintReport")
Set NV = db.GetView("BSUCodes")
strPicker = ws.DialogBox("UCodePicker",True,True,True,True,False,False,"Clyde Pumps - I.T. Service Desk")
If strPicker = True Then
	strUCode = s.GetEnvironmentString("UCode")
	Set NDoc = Nv.GetDocumentByKey(strUCode)
	strName = NDoc.ActualNameTX(0)
strFormula = "SELECT Form = ""FLS Call"" & status = ""Open"" & GivenTo = """ & strName & """"
v.SelectionFormula = strFormula
uidb.OpenView("PrintReport")
Set uiv = ws.CurrentView
Call uiv.Print(,,,,,,True,,)
'Press the TAB key Twice
keybd_event 9,0,0,0 ' Tab key down
keybd_event 9,0,2,0 ' Tab key up
'Press the UP KEY once
keybd_event 30,0,0,0 ' Up key down
keybd_event 30,0,2,0 ' Up key up
'Press the TAB key nine times!
'Press enter to print
keybd_event 13,0,0,0 ' Return key down
keybd_event 13,0,2,0 ' Return key up
Anyone offer any help,
F1H
Subject: Keypress values - Help
but its not working
You gotta give us more than that. Have you tried debugger? Can you identify which line it fails to work.
Buddy, Are u missing declaration section like one below?..hope this help
Declare Sub keybd_event Lib “user32.dll” (Byval bVk As Integer, Byval bScan As Integer, Byval dwFlags As Integer,Byval dwExtraInfo As Integer)
Sorry, I can’t figure out what you are trying to do. You say you want to print the current view, but where/when? Why isn’t the user simply using Ctrl-P?
Cheers,
Adrian
