Key-problem after reinstalling the client
Hi :slight_smile: - I got a problem with the Client/Server after reinstalling the client.The error-message is (Directly translated):
“The present public key is not the same as the certified key. Read the local ptorocol-file. Do you still want to access the server ?”.
Since my data-hd crashed, the data-files of notes are gone (except my mailbox, Notes.ini and the ID-files), so I reinstalled the client and copied the remaining files to that dir.
What’s wrong ?
Subject: Key-problem after reinstalling the client
I think your problem is that the ID was re-certified and not copied to your repository that you still have, in other words the ID is older than the one used.
You can correct this by copying the key from the ID file and pasting it on the person document. This doesn’t always work though.
Cheers
Subject: Re:Key-problem after reinstalling the client
Right, that is what I think so, too…But I’ve got the same problem for both the admin and the user-ID, so I cannot access the Domino-server.
Is there a way to access the server anyway ?
Thanks for your answer :slight_smile: - Henrik
