JS syntax problem
Dear all,I have this JS validations on a button. All i want to do is check a combo field and call other functions in JS header according to that. After validating all i’m calling a button click event…I couldn’t make this run at all…Pls help me…
Thanks in advance
Shana
if (document.forms[0].Fld_Catg.selectedIndex == 0) then
a=isEmptymessage(document.forms[0].St_Date.value,“Start Date”)
if (a ==true) {
a=isValidDate(document.forms[0].St_Date.value)
if (a ==true) {
a=isEmptymessage(document.forms[0].End_Date.value,“End Date”)
if (a ==true) {
a=isValidDate(document.forms[0].End_Date.value)
if (a ==true) {
a=dateOrder(document.forms[0].St_Date.value,document.forms[0].End_Date.value)
else if (document.forms[0].Fld_Catg.selectedIndex == 1) then
a= isEmptyCombo(document.forms[0].Fld_ResPers.value,“Responsible Person”)
else if (document.forms[0].Fld_Catg.selectedIndex == 2) then
a= isEmptyCombo(document.forms[0].Fld_Division.value,“Responsible Person”)
if (a ==true) {
document.forms[0].SearchDB2.click();
Subject: JS syntax problem…
I didn’t really dive into your code (it’s early in the morning here), but what can help debug the javascript is: try Firefox as a browser and install the extension “Firebug” - this tool will show you the exact line where the script goes bad.
Martin Vereecken
http://www.bizzybee.be (Notes blog)
Subject: RE: JS syntax problem…
In addition check JavaScript Tutorial
In Javascript condition statment “then” is not required.
if (conditon) (
// if true I do that… or I return what I want
// Example : a message and return true
alert(‘It’s true’)
return true;
} else {
/* If false, I do that… or I return what I want
Example : a message and return false */
alert(‘It’s false’)
return false;
HTH
Thierry
