Hi, I ve the follow code:
var xmlDoc=new ActiveXObject(“…”)
xmlDoc.load(“…”)
//xmlDoc.async="false"
var x = xmlDoc.getElementsByTagName(“…”) <<— line Y
var result = x.item(0).text <<— line X
if(“…” != resul)
alert('Access Denied');
window.parent.location = \"?logout\";}
else
alert('Wellcome)');
When I try to load this code through a browser (in the X line) raise an error, “The data necessary to complete this operation is not available yet” in the bottom left corner. It reference to line “X”.
But when I write “alert(x)” between line “Y” and line “X” the var “result” is loaded OK.
Note: I can’t write any alert message in this code.
Any suggestion to solve this problem?
Thanks a lot !! It´s driving me crazy.
Santiago.
