Javascript problem..Please help
****EDIT*****I figured it out…I have:
var msg;
var missing;
It should be:
var msg = “”;
var missing = “”;
EDIT**
Hey guys…This is going to be kinda long. Bare with me…I can use some help…Right now its just validating 1 Field(ContactName).
If the Field is Blank and i click on the button the alert message comes up.
ALERTBOX
UndefinedPlease correct your entries…
-------------------------------Undefined
the following fields are missing:Undefined
-ContactName is a required Field.
ALERTBOX
I don’t understand why Undefined is there. It shouldn’t be.
Now if i add text to the ContactName Field and click the button, Internet Explorer shows me a javascript error message in the bottom left corner, that reads:
Line: 17
Char: 3
Error: ‘length’ in null or not an object
Netscape says: ‘Missing’ has no properties.
if(missing.length !=0)
Heres the javascript validation:
function validate(frm)
	var missing;
	var msg;
for(i=0; i<document.forms[0].elements.length; i++)    // loop through form elements
	var el = document.forms[0].elements[i];
	if(el.required)
	    if(isEmpty(el))
			missing += "\n   - " + el.name + " is a required field";
// build output message
		msg += "\n\nThe following required fields are missing:";
		msg += missing;
	errMsg(msg);           // call the output function
	msg = ""; missing = ""; // reset all our variables
	return false;
else
	return true;
function isEmpty(field)
str = field.value;
if(str == "")
	return true;
else
	for(j=0; j<str.length; j++)
		if(str.charAt(j) != " ")
			return false;
return true;
function errMsg(msg)
var theMsg = "You entered some incorrect values into the form. ";
theMsg += "Please correct your entries then re-submit the form.\n";
theMsg += "____________________________________________________________________";
theMsg += msg;
theMsg += "\n____________________________________________________________________\n";
alert(theMsg);
In the button i have:
document.forms[0].ContactName.required = true;
return validate(document.forms[0]);
Any suggestiong would be very helpful…Thanks a bunch guys!!!
-Jordan
