I have a radio btn field called “DeliveredBy” which , when “Staff Member” is selected, displays several other fields. Some of these fields are Date type and next to them are a Computed for Display field that, with the help of a formula, display a calendar icon that will bring up a calendar popup window when clicked.
In the “DeliveredBy” field’s on Click event I have some javascript code that does the job well for most of the fields but it can’t hide the calendar icon. Can someone tell me how this can be accomplished? The two variables in question are “DelDateImage” and “RecDateImage”.
Thanks for any help provided.
Dan
Here is the code:
var f = document.forms[0];
var empList = f.elements(“DeliveryEmpList”);
var DeliveredDateText = f.elements(“DeliveredDateLbl”);
var DelDate = f.elements(“DeliveredDate”);
var DelDateImage = f.elements(“dtHTML_B”);
var ReceivedByText = f.elements(“ReceivedByLbl”);
var Received = f.elements(“ReceivedBy”);
var ReceivedDateText = f.elements(“ReceivedDateLbl”);
var RecDate = f.elements(“ReceivedDate”);
var RecDateImage = f.elements(“dtHTML_C”);
if(this.checked && this.value == “Staff Member”) {
//_doClick(‘$Refresh’,this,null);
empList.style.visibility = “visible”;
DeliveredDateText.visibility = “visible”;
DelDate.style.visibility = “visible”;
DelDateImage.style.visibility = “visible”;
ReceivedByText.visibility = “visible”;
Received.style.visibility = “visible”;
ReceivedDateText.visibility = “visible”;
RecDate.style.visibility = “visible”;
RecDateImage.style.visibility = “visible”;
empList.focus();
else {
empList.style.visibility = “hidden”;
DeliveredDateText.visibility = “hidden”;
DelDate.style.visibility = “hidden”;
DelDateImage.style.visibility = “hidden”;
ReceivedByText.visibility = “hidden”;
ReceivedDateText = “hidden”;
Received.style.visibility = “hidden”;
RecDate.style.visibility = “hidden”;
RecDateImage.style.visibility = “hidden”;
