I have been using Java to fetch Data from DB2 Database and display the data in a already opened (in edit mode) Notes Form in Notes Client.
Now what I watched is that I am able to set value to the form fields in backend only. That is, while the agent executes the field on the form does not populate with data in front-end. Now if I close the document and then re-open it the populated data starts showing.
How can I populate document’s fields while the document is still opened as is done in Lotus Script ?
Is it at all possible ? How?
Is it possible to access the front-end document as can be done in Lotus Script .
I am new to Notes-Java, so please be patient with me.
Any advice would be greatly appreciated.
Thanks in Advance
Sudip
