Java problem http srv
Suddenly my Domino http server will not start and saying something like this.
JVMJ9VM015W library J9GC24<2> Error.
Java Virtual Machine Faild to start.
Please Help.
Subject: disable the JVM
if you disable the jvm, are you able to load the http task?
set the following in the notes.ini
HTTPDisableJVM=1
you may have a corrupted jvm
I’ve ran into an issue in the past that required me to reinstall the server/ copy the jvm from a working server
Subject: I see this on an upgrade today…
  • When you mention copying the JVM from a good server, do I simply copy the entire jvm directory from a good server to this one? There’s no server-specific configuration I have to worry about?
  • Thanks for your time…
