JAVA_HOME does not work!
How does IBM/Domino determine the correct version of Domino?
JVM: Correct version of Java not installed.
http://www-01.ibm.com/support/docview.wss?uid=swg21632959 http://www-01.ibm.com/support/docview.wss?uid=swg21632959
Reference #: 1632959
Why does it not use the JAVA_HOME from the notes.ini?
If I had used JAVA_HOME for it’s intended purpose, 64bit, and removed the 32 bit via DLTLICPGM, would I still get this error?
ENDDOMSVR GDI01
CRTSAVF FILE(ROB/Q5770JV111)
CRTSAVF FILE(ROB/Q5770JV112)
SAVLICPGM LICPGM(5770JV1) DEV(*SAVF) OPTION(11) SAVF(ROB/Q5770JV111)
SAVLICPGM LICPGM(5770JV1) DEV(SAVF) OPTION(12) SAVF(ROB/Q5770JV112)
EDTF STMF(‘/gdi01/notes/data/notes.ini’)
Added one line at the bottom:
JAVA_HOME=/QOpenSys/QIBM/ProdData/JavaVM/jdk80/64bit
DLTLICPGM LICPGM(5770JV1) OPTION(11)
DLTLICPGM LICPGM(5770JV1) OPTION(12)
WRKLNK '/QOpenSys/QIBM/ProdData/JavaVM/
Object link Type
jdk626 DIR
jdk70 DIR
jdk71 DIR
jdk80 DIR
STRDOMSVR GDI01
WRKDOMSVR
*STARTED
9=Work server jobs
:frowning: No HTTP job
DSPDOMCSL
HTTP Server: Using Internet Site Configuration View
JVM: Correct version of Java not installed. Refer to the software requirements and install the correct Java option.
JVM: Java Virtual Machine failed to start
HTTP Server: Error Loading Java Virtual Machine
HTTP Server: JVM: Missing entrypoint in JVM runtime library.
HTTP Server: Shutdown
