Java Help Requested!
I’ve found a bit of free code for zipping files in Java with basic instr. What I don’t understand is how to get it to work as I had hoped. If anyone out there would be kind enough to help that would be great!
The idea is to call a java agent from lotus script and pass the folder I want zipped (there is plenty of documentation on this, i first want to get it to work with a hard coded folder as in the below obviously incorrect code).
This is the source for the Java library.
FYI: The (Use “ZIP”) is the name of the java libray below & for security reasons the %folder% represents the entire path including drive letter. Most of this code is the
// Command Line:
// java ZipBackup [-options] []
// Parameters:
// options (Optional):
// r = Recursive folders (default)
// R = do not do Recursive folders
// l = enable Logging
// L = disable Logging (default)
// q = Quiet Mode (default)
// Q = non-Quiet Mode (displays progress to console)
// f = use Folder-script mode; uses folder as script
// F = normal script mode (not Folder Mode) (default)
// 0-9 = Level of compression to use; 0 - no compression; 9 - maximum compression (default)
// archive-folder:
// location to store Zip files generated by ZipBackup; typically I put all backup zip files in a “c:\archive” folder.
// script:
// Specify the Text file containing instructions for performing file backups. Right now, the format is simple: one line containing the path to each folder you want backed-up.
// suffix:
// Optional. To help organize zip files containing specific content, you may append a file “suffix”.
// %EndRem
// '*** Class Code Below ***
import java.util.*;
import java.io.*;
import java.util.zip.*;
import java.text.*;
public class ZipBackup
String zipFileName = null;
String logFileName = null;
Map archiveQue = null;
LogFile log = null;
String archiveLocation = null;
String fileSeparator = null;
// options
boolean doFolderMode = false;
boolean doLogging = false;
boolean doRecursion = true;
boolean doQuietMode = true;
int compression = 9;
int recursionLevel = 0;
public ZipBackup(String[] args)
    boolean useOptions = false;
    if (args.length > 0)
        if (args[0].trim().startsWith("-"))
            useOptions = true;
            parseOptions(args[0].trim());
    if ((useOptions && args.length < 3) || (!useOptions && args.length < 2))
        // invalid number of arguments, so display usage message
        printUsageMessage();
        return;
    String scriptFileName = null;
    String fileNameSuffix = null;
    if (useOptions)
        if (args.length >= 3)
            archiveLocation = args[1].trim();
            scriptFileName = args[2].trim();
        if (args.length >= 4)
            fileNameSuffix = args[3].trim();
    else
        if (args.length >= 2)
            archiveLocation = args[0].trim();
            scriptFileName = args[1].trim();
            fileNameSuffix = args[2].trim();
    generateZipFileName(archiveLocation, fileNameSuffix);
    if (doLogging)
        log = new LogFile(logFileName, !doQuietMode);
        log.println("Zip File Name: " + zipFileName);
    if (!doLogging && !doQuietMode)
        System.out.println("Zip File Name: " + zipFileName);
    List scriptEntrys = null;
    if (doFolderMode)
        scriptEntrys = new ArrayList();
        scriptEntrys.add(scriptFileName);
    else
        scriptEntrys = parseArchiveScript(scriptFileName);
        if (scriptEntrys == null)
            log.close();
            return;
    try
        setupArchiveMap(scriptEntrys);
        if (doLogging)
            log.println("Start Creating Zip");
        else
            if (!doQuietMode)
                System.out.println("Start Creating Zip");
        create();
        if (doLogging)
            log.println("Finished Creating Zip");
        else
            if (!doQuietMode)
                System.out.println("Finished Creating Zip");
    catch (Exception e)
        if (doLogging)
            log.printException(e);
        else
            e.printStackTrace();
    finally
        if (doLogging)
            log.close();
private void setupArchiveMap(List archiveFolders)
    archiveQue = new HashMap();
    File myFolder = null;
    for (Iterator it = archiveFolders.iterator(); it.hasNext(); )
        myFolder = new File((String) it.next());
        if (myFolder.exists())
            recursionLevel = 0;
            addToArchiveQue(myFolder);
private void addToArchiveQue(File file)
    recursionLevel++;
    if (file.isDirectory())
        if (doRecursion || recursionLevel < 2)
            File[] files = file.listFiles();
            List fileList = Arrays.asList(files);
            for (Iterator it = fileList.iterator(); it.hasNext(); )
                addToArchiveQue((File) it.next());
    else
        String fileName = file.getAbsolutePath();
        String entryName = convertToEntryName(fileName);
        archiveQue.put(entryName, fileName);
private String convertToEntryName(String filename)
    int dirColon = filename.indexOf(":");
    if (dirColon != -1)
        filename = filename.substring(dirColon + 2);
    filename = filename.replace('\\', '/');
    return filename;
private void generateZipFileName(String location, String suffix)
    String fileSeparator = System.getProperty("file.separator");
    Calendar cal = Calendar.getInstance(); // gets current date/time
    int year = cal.get(Calendar.YEAR);
    int month = cal.get (Calendar.MONTH);
    int day = cal.get(Calendar.DAY_OF_MONTH);
    int hour = cal.get (Calendar.HOUR_OF_DAY);
    int minute = cal.get(Calendar.MINUTE);
    int second = cal.get(Calendar.SECOND);
    NumberFormat format = NumberFormat.getInstance();
    format.setMinimumIntegerDigits(2);
    format.setMaximumIntegerDigits(2);
    format.setMinimumFractionDigits(0);
    format.setMaximumFractionDigits(0);
    StringBuffer filename = new StringBuffer();
    filename.append(location);
    // if the directory location does not end with the file separator,
    // then append it before the file name.
    if (!location.endsWith(fileSeparator))
        filename.append(fileSeparator);
    filename.append("archive-");
    filename.append(year);
    filename.append("-");
    filename.append(format.format(month + 1));
    filename.append(format.format(day));
    filename.append("_");
    filename.append(format.format(hour));
    filename.append(format.format(minute));
    filename.append(format.format(second));
    if (suffix != null)
        filename.append(suffix);
    zipFileName = filename.toString() + ".zip";
    logFileName = filename.toString() + ".log";
private List parseArchiveScript(String fileName)
    File myFile = new File(fileName);
    File testFile = null;
    if (!myFile.exists() || myFile.isDirectory())
        return null;
    FileReader fileReader = null;
    try
        fileReader = new FileReader(myFile);
        BufferedReader read = new BufferedReader(fileReader);
        List myList = new ArrayList();
        String line = null;
        while ((line = read.readLine()) != null)
            line = line.trim();
            if (line.length() > 0)
                testFile = new File(line);
                if (testFile.exists())
                    myList.add(line);
        return myList;
    catch (Exception e)
        return null;
    finally
        try
            fileReader.close();
        catch (IOException ioe)
            log.printException(ioe);
private void create()
    throws IOException
    ZipOutputStream zipStream =
        new ZipOutputStream( new FileOutputStream(zipFileName));
    zipStream.setLevel(compression);
    Map.Entry entry = null;
    String currentFileName = null;
    String currentEntryName = null;
    FileInputStream fis = null;
    byte[] buffer = new byte[ 10240 ];
    int readLength = 0;
    int fileCount = archiveQue.size();
    int count = 0;
    double percent = 0.0;
    NumberFormat format = NumberFormat.getPercentInstance();
    format.setMaximumFractionDigits(1);
    format.setMaximumIntegerDigits(3);
    format.setMinimumIntegerDigits(1);
    for (Iterator it = archiveQue.entrySet().iterator(); it.hasNext(); )
        entry = (Map.Entry) it.next();
        currentEntryName = (String) entry.getKey();
        currentFileName = (String) entry.getValue();
        count++;
        zipStream.putNextEntry( new ZipEntry(currentEntryName) );
        fis = new FileInputStream(currentFileName);
        if (doLogging)
            log.print(currentFileName);
            percent = (double) count  / fileCount;
            log.println(" (" + count + " of " + fileCount +  "; " + format.format(percent) + ")");
        for (int i = 0; ; i++)
            readLength = fis.read(buffer);
            if (readLength < 0)
                if (doLogging)
                    log.println("=" + i);
                break;
            zipStream.write(buffer, 0, readLength);
            if (doLogging)
                if ((i % 10) == 0)
                    log.print("*");
        fis.close();
        zipStream.closeEntry();
        if (doLogging)
            log.println();/*
public PrintWriter getPrintWriter()
    return this.logPrintWriter;
        if (!doQuietMode && !doLogging)
            if ((count % 10) == 0)
                System.out.print("*");
    zipStream.close();
        System.out.println("Archived " + count + " of " + fileCount);
    if (doLogging)
        log.println();
        log.println("Archived " + count + " of " + fileCount);
private void parseOptions(String options)
    if (options.indexOf("Q") != -1)
        this.doQuietMode = false;
    if (options.indexOf("q") != -1)
        this.doQuietMode = true;
    if (options.indexOf("L") != -1)
        this.doLogging = false;
    if (options.indexOf("l") != -1)
        this.doLogging = true;
    if (options.indexOf("R") != -1)
        this.doRecursion = false;
    if (options.indexOf("r") != -1)
        this.doRecursion = true;
    if (options.indexOf("F") != -1)
        this.doFolderMode = false;
    if (options.indexOf("f") != -1)
        this.doFolderMode = true;
    if (options.indexOf("0") != -1)
        this.compression = 0;
    else if (options.indexOf("1") != -1)
        this.compression = 1;
    else if (options.indexOf("2") != -1)
        this.compression = 2;
    else if (options.indexOf("3") != -1)
        this.compression = 3;
    else if (options.indexOf("4") != -1)
        this.compression = 4;
    else if (options.indexOf("5") != -1)
        this.compression = 5;
    else if (options.indexOf("6") != -1)
        this.compression = 6;
    else if (options.indexOf("7") != -1)
        this.compression = 7;
    else if (options.indexOf("8") != -1)
        this.compression = 8;
    else if (options.indexOf("9") != -1)
        this.compression = 9;
private void printUsageMessage()
    StringBuffer sb = new StringBuffer();
    sb.append("Usage: \n");
    sb.append("\tjava com.taylor.zip.ZipBackup [-<opts>] <archive> <script> [<suffix>]\n");
    sb.append("\n\n");
    sb.append("Parameters\n");
    sb.append("==========\n");
    sb.append("\topts:\t\tr   = recursive folders (default)\n");
    sb.append("\t\t\tR   = no recursive folders\n");
    sb.append("\t\t\tl   = enable logging\n");
    sb.append("\t\t\tL   = disable logging (default)\n");
    sb.append("\t\t\tq   = enable quiet mode (default)\n");
    sb.append("\t\t\tQ   = disable quiet mode\n");
    sb.append("\t\t\tf   = folder is script\n");
    sb.append("\t\t\tF   = script text file (default)\n");
    sb.append("\t\t\t0-9 = Compression level 0 (store only) to 9 (best). \n");
    sb.append("\t\t\t      9 is default.\n\n");
    sb.append("\tarchive:\tlocation (folder/directory) to create archive files\n");
    sb.append("\tscript:\t\ttext script file (list of directories on each line)\n");
    sb.append("\t\t\t or specific directory to backup (use with -f option)\n");
    sb.append("\tsuffix:\t\tsuffix to append to end of archive file name\n");
    System.out.println(sb.toString());
public static void main(String[] args) {
    ZipBackup testProcessExec = new ZipBackup(args);
    testProcessExec.invokedStandalone = true;
private boolean invokedStandalone = false;
private class LogFile
private String logFileName;
private boolean echoToSystemOut = false;
private PrintWriter logPrintWriter;
private boolean isActive = false;
public LogFile(String logFileName, boolean echoOn)
    String dirSeparator = System.getProperty("file.separator");
    String tempDir = System.getProperty("java.io.tmpdir");
    this.echoToSystemOut = echoOn;
    if (logFileName.indexOf(dirSeparator) > -1)
        this.logFileName = logFileName;
    else
        this.logFileName = tempDir + dirSeparator + logFileName;
    try
        this.logPrintWriter =
        new PrintWriter(new FileOutputStream(this.logFileName));
        this.isActive = true;
    catch (IOException e)
        System.out.println("Problems creating/open " + this.logFileName);
public String getLogFileName()
    return this.logFileName;
public boolean isActive()
    return this.isActive;
public void close()
    if (this.isActive)
        this.logPrintWriter.close();
    this.isActive = false;
public void println(String text)
    if (this.isActive)
        this.logPrintWriter.println(text);
        if (this.echoToSystemOut)
        System.out.println(text);
        this.logPrintWriter.flush();
public void println(Object obj)
    if (this.isActive)
        this.logPrintWriter.println(obj);
        System.out.println(obj);
public void println()
    if (this.isActive)
        this.logPrintWriter.println();
        System.out.println();
public void print(String text)
    if (this.isActive)
        this.logPrintWriter.print(text);
        System.out.print(text);
public void printList(List list)
    if (this.isActive)
        for (Iterator it = list.iterator(); it.hasNext(); )
            println(it.next());
public void printMap(Map map)
    if (this.isActive)
        for (Iterator it = map.entrySet().iterator(); it.hasNext(); )
            println(entry.getKey() + " = " + entry.getValue());
public void printException(Exception e)
    if (this.isActive)
        e.printStackTrace(this.logPrintWriter);
        e.printStackTrace(System.out);
public String toString()
    sb.append ("Log File: " + this.logFileName);
    sb.append (" Active: " + this.isActive);
    sb.append (" Echo to System.out: " + this.echoToSystemOut);
    return sb.toString();
// **** This is the code I have in the agent ***
Use “ZIP”
Uselsx “*javacon”
Dim mySession As JavaSession
Dim myClass As JavaClass
Dim archive As JavaObject
Dim c As Integer
Set mySession = New JavaSession()
Set myClass = mySession.GetClass("ZipBackup")
Set archive = myClass.CreateObject()
c = archive.ZipBackup(  "%folder%" )
Subject: Java Help Requested!
disregard
I understand that the Java code here will ZIP attachments in a specified folder. I did not test it, but I tested other ZIP Java code which can be found in web link below which did not work properly in all cases.
http://www-10.lotus.com/ldd/46dom.nsf/DateAllFlatweb/2cee3523b108776185256edf005c0715?OpenDocument
You might want to try a 3rd party tool such as AttachZIP.
http://www.notesmail.com/AttachZIP
-Matt
Rick,Calling Java from LotusScript is hard, but it can be done.
If you want to use your technique again it is worth the trouble otherwise you might be better off using Java outside Domino.
Send me an email and I will give you some instructions on how to do it if you like.
Regards
Rolf Pfotenhauer
email: rolfpf@yahoo.com.au
