Java & DXL Concurrency problems
Hi there,
I am developing a servlet using Java and Domino server 5 & 6. I am using the Lotus XML Toolkit, DXL Release 1.0. For my testcase I use the DXL example servlet for exporting by web the xml of a data base or a view.
Everything seems to work fine until I make an stress test. With five concurrent users after less than five minutes the nHttp task deads!!!
I get this error:
lotus.dxl.DXLExportException: Unknown DXL class library error.
The windows nHTTP task shows and error window saying: Application error → Memory Possition XXXX can not be read.
Does anybody have the same problem?.
Thanks in advance,
Sergio
