Java applet for views with problems after migration
Hi folks,
I started developing notes already in R6. And now im supposed to fix some “bugs” due to the migration from R5 apps´ to R6.
So here is my problem…
The user application uses the java applet to show views on web, and after migrating to R6, the view´s header is gone and so two action buttons(other 3 remains there, how? i dont know).
The applet shows the view´s content, but not its header.
What i need to know, if there is/are problems with some view´s options ( those checkboxes) that works on R5 but does not at R6…
because the application was migrated , and its code remains the same since R5 … so it looks like some kind of “problem” with R5->R6…
Is there anything u can tell me so i can keep trying to find out what the hell is going wrong…
Thanks in advance!
/fferrandini
Subject: Java applet for views with problems after migration
This sounds similar to the problem when you migrated from LN 4 to LN5 and the disappearance of Action Bar Buttons Here was the technote I had for that - incase it helps any :
http://www-1.ibm.com/support/docview.wss?rs=0&uid=swg21089958
Hope it’s not a wild goose chase.
Subject: RE: Java applet for views with problems after migration
Thanks Stephen,
I will provide R5 designer and i will do the test as described in your link.
But im already getting crazy trying to understand why the view header( the columns names…) dissapeared, in other cases i did use embedded view with java applet in R6.x and it worked fine… dont know…
and i just saw another problem…
the same view in question, has a column with numeric values, and on its properties says “display values as icons” , using notes icons, and on web it shows the number, on client it shows the relative icon…
damn now im crazy!
