Java agent problem for PDF creating
Hello all,
i am having java agent that is not creating pdf? do any body have any idea i am commeting where it gets struck!!!
import lotus.domino.*;
import java.io.*;
import java.util.*;
public class JavaAgent extends AgentBase
public void NotesMain()
	synchronized(this)
		logfile("Create PDF Start Here");
		Document logDoc=null;
		RichTextItem rti=null;
		try
			//	trying  new from here
			logfile("try");
			Session session = getSession();
			AgentContext agentContext = session.getAgentContext();
			Database db = agentContext.getCurrentDatabase();
			Agent agent = agentContext.getCurrentAgent();
			//	now initialising to create logs
			logDoc = db.createDocument();
			logfile("LogDoc Created");
			logfile("try1");
		     logDoc.appendItemValue("Form", "Log");
		     DateTime dt = session.createDateTime("Today");
		     dt.setNow();
		     logDoc.appendItemValue("LogDate", dt);
			logfile("Hello1");
 	 		rti = logDoc.createRichTextItem("Logbody");
  			//	EOFnow initialising to create logs
			//	Get document used for passing data
			Document doc = db.getDocumentByID(agent.getParameterDocID());
			logfile("Credit Note Document is Set  to Get File Path");
			//	getting the request parameters
			String xslFilePath = doc.getItemValueString("XSLFILEPATH") ;
			String xmlFilePath = doc.getItemValueString("XMLFILEPATH") ;
			String pdfFilePath = doc.getItemValueString("PDFFILEPATH") ;
			File fxsl=new File(xslFilePath);
			File fxml=new File(xmlFilePath);
			logfile(xmlFilePath);
			logfile(pdfFilePath);
			logfile("File Path Found ");
			if( fxsl.exists()  && fxml.exists())
				logfile("Enter into IF");
				//	EOF getting the request parameters
				//	calling the pdf creation method
				Runtime rt=Runtime.getRuntime();
				String sCommand="java
PDFCode.trying “+xmlFilePath+” “+xslFilePath+” “+ pdfFilePath; //// Problem gets here”“” ///
				logfile("Try3");
///"java PDFCode.trying “+xmlFilePath+” “+xslFilePath+” "+ pdfFilePath;
				logfile(sCommand);
				Process p=rt.exec(sCommand);
				InputStream ins=p.getInputStream();
				int r=0;
				String  sTemp="";
				logfile("Start Creating PDF");
				do
					r=ins.read();
					sTemp = sTemp+ (char)r;
				while(r!=-1);
				//	EOF of calling the pdf creation
				//	now attaching the pdf in mail
				logfile("PDF Created");
				File fpdf=new File(pdfFilePath);
				if(fpdf.exists())
					logfile("Pdf Found ");
					RichTextItem body = doc.createRichTextItem("CreditNotePDF");
					if(body==null)
					logfile("the body is null");
					body.embedObject(EmbeddedObject.EMBED_ATTACHMENT,null, pdfFilePath,"");
					logfile("Embedade Object Done");
					//	Memo to Customer
					Document memo = db.createDocument();
					logfile("Memo 1");
					memo.appendItemValue("Form", "Memo");
					memo.appendItemValue("Subject", doc.getItemValueString("MailSubject"));
					logfile("Memo 2");
					RichTextItem MailBodyRTI = memo.createRichTextItem("Body");
					Item item = doc.getFirstItem("MailBody");
					logfile("Memo 3");
					Enumeration values = null;
					if(item!=null)
						Vector vec=new Vector();
						vec=item.getValues();
						if(vec!=null)
						values=vec.elements();
					else
						logfile("item is null");
				if(values !=null)
					logfile("coming in this");
					while (values.hasMoreElements())
						String sVal=(String)values.nextElement();
						logfile("sVal is    "+sVal);
						if(sVal==null)
							sVal=" ";
						MailBodyRTI.appendText(sVal);
						logfile("after appnd");
						MailBodyRTI.addNewLine();
				else
					logfile("coming in null");
					MailBodyRTI.appendText(" ");
				logfile("Memo 4");
				MailBodyRTI.embedObject(EmbeddedObject.EMBED_ATTACHMENT,null, pdfFilePath,"");
				logfile("Memo 5");
				Vector v = new Vector();
				//	v.addElement(doc.getItemValueString("EMailID"));
				//	v.addElement(doc.getItemValueString("MailTo"));
				logfile("Memo 6");
				logfile(doc.getItemValueString("MailTo"));
				String sEmails=doc.getItemValueString("EMailID");
				logfile("coming in EmailID   "+sEmails);
				StringTokenizer tok=new StringTokenizer(sEmails,",");
				Vector vecMail=new Vector();
				while(tok.hasMoreElements())
					String sEmail=(String)tok.nextElement();
					vecMail.addElement(sEmail);
					logfile("appending  "+sEmail);
				memo.appendItemValue("SendTo",vecMail);
				vecMail.removeAllElements();
				sEmails=doc.getItemValueString("MailTo");
				logfile("coming in MailTo   "+sEmails);
				memo.appendItemValue("CopyTo",vecMail);
				logfile("Memo 7");
				memo.send(false,v);
				logfile("M sent");
				//	Memo End Here
				//	changing the status of the document
				doc.replaceItemValue("Status", "Sent");
				Item MailBodyItem = doc.getFirstItem("MailBody");
				MailBodyItem.remove();
				Item MailSubjectItem = doc.getFirstItem("MailSubject");
				MailSubjectItem.remove();
				Item MailToItem = doc.getFirstItem("MailTo");
				MailToItem.remove();
				doc.save(true);
				logfile("after getting ricch text ");
				logfile("end");
				//	deleting the files after work is done
				fxml.delete();
				fpdf.delete();
				//	EOFdeleting the files after work is done
				else
					rti.appendText("No PDF Found");
					fxml.delete();
					logfile("no PDF file");
					logDoc.save();
				//	EOFnow attaching the pdf in mail
			else
				rti.appendText("xsl>"+fxsl.exists()+" xml>"+fxml.exists());
				logfile("xsl>"+fxsl.exists()  +" xml>"+ fxml.exists() );
				logDoc.save();
		catch(Exception e)
			logfile(e.toString());
		try
			if(rti != null)
				rti.appendText(e.toString());
				logDoc.save();
		catch(Exception ex)
			logfile(ex.toString());
	//	EOF of sync
public void logfile(String txt)
	try
		String path="c:/hello.txt";
		File ff=new File(path);
		FileOutputStream fos=null;
		if(ff.exists())
			if(ff.length() > (1024 * 1024) )
				fos=new FileOutputStream(path);
			else
				fos=new FileOutputStream(path,true);
		}else
		PrintWriter prn=new PrintWriter(fos);
		prn.println(txt);
		prn.flush();
		fos.close();
	catch(Exception e)
