I have the following code behind a page hotspot:
targetdatabase:=“Msidmast.nsf”;
Server:=@Name([Abbreviate];@Subset(@DbName;1));
dir:=@LeftBack(@Subset(@DbName;-1);“\”);REM {Returns current directory without file name.};
path:=@If(dir=“”;“ISOx6\”;dir+“\”)+targetdatabase;
@SetTargetFrame(“Frame2”);
@PostedCommand([FileOpenDatabase]; Server : path );
@PostedCommand([OpenView]; “All Documents”);
@PostedCommand([ViewCollapseAll]);
@PostedCommand([ViewShowSearchBar];“1”)
The code opens the view in Frame2 of the frameset, showing the search bar just fine. But the code also opens the view in a completely different window as well, and when I try to close this window, Notes blows up on me.
How do I change this code to open the view in Frame2 only?
The view is in a different database from the one I have the above code in.
Is there something I need to change on the view itself? Or the DB properties that the view is in?
Thanks,
Chad
