IsOpen problem
I am using the following code in an agent
Set NABDB = New NOtesDatabase(“”,“names.nsf”)
If NABDB.isOpen Then
mseeagebox “Databse is opened”
else
messagebox “DB not opened”
end if
when I run this I am getting “DB not opened” message, bu tthe names.nsf is a valid database present in the same server .
Can any one of you tell when this can occur and how to overcome this.
Subject: IsOpen problem
I know that is help is written that if server and filepath are present then the object is open, but that is not always true.After seting database - either throu session or as New I always call db.Open(“”,“”)
Call nabDB.Open(“”,“”)
else
end if
Subject: RE: IsOpen problem
Thanks Elka,
I am opening the DB using
So then no need to open the DB,
but “If NABDB.isOpen Then” condition fails.
If your agent is started by User or is called with agent.Run then you are opening that user’s personal AddressBook.If you call agent with agent.RunOnServer - than you will get the server’s NAB. It works OK on my site.
I tried your code (correcting some missspelling) and it gives me that NABDb is open - My
If you want to access the NAB on a server different from local, than you sould write the name of the server.
So what I was trying to say is that sometimes set nabdb with all parameters is not enough. You are loosing nothing if you add
after setting it with New or with sesseion.getDatabase.
GoodLuck.
“The owls are not what they seem.”
