Is there any way to by pass delete message of Lotus Notes or delete attachments in the body using formula language?
I am deleting attachments present in the Body of Calendar using formula language. I am using following code to delete the Body contents.
@Command([EditGotoField];“Body”);
@Command( [EditSelectAll] );
@Command([Clear]);
@Command( [ToolsRefreshAllDocs] ) ;
But if attachments are present in the Body I am getting following message box of Lotus Notes:
“This operation cannot be undone. Do you wish to proceed? (Yes/No)”
Is there any way to by pass this message or delete attachments in the body using formula language?
Any help would be appreciated.
Thanks,
Abhi
Subject: Is there any way to by pass delete message of Lotus Notes or delete attachments in the body using formula language?
I had a similiar problem. The only solution that worked properly (without message box) was to switch to Lotus Script.
I use the following Lotus Script command:
Call notesUIDocument.FieldClear( [ fieldName$ ] )
