I’m trying to find out if one of our servers is running in 64 bit mode. I looked at the results from the show server command, but it does not say. Is there a way to tell??
Subject: How about show stat server command?
sever.version.architecture tells if you’re running 32 bit / 64 bit.
Subject: What’s your platform?
I’m just winging this - but on the windows platform there are separate server builds for 32 bit and 64 bit - on a 64 bit machine I believe that you can install either, but a 32 bit build will only run 32 bit.
Subject: RS/6000
I’m on a RS6000 running AIX 5.3.
Subject: AIX
Plus the server was installed quite a while ago. And we are using Trend Micro Scan Mail for Domino. For their version 5, they did not have one for AIX. I’m not sure if I digressed back to 32 bit. I could just re-install the server if necessary.
