Hi all, I have the following problem. I have a couple of checkboxes and radiobuttons. They all work fine but when I am in read-mode I can still change this boxes and buttons. The changes are not saved or anything, but I would to just disable/lock this things. Is this possible and how to do this?
Greetz
Subject: Is there a way to disable a checkbox in read-mode?
Okay, I’ve allready found a solution. Because my radio buttons and checkboxes are in HTML in read-mode I can add the parameter “disabled”. For the lotus notes fields this also possible in the HTML tab.
Subject: RE: Is there a way to disable a checkbox in read-mode?
Bram,
An alternative would be to hide the control fields when the document is in read mode and instead display them with separate display-only fields. That will also provide the benefit of only displaying what was actually chosen by the user - in my opinion it gives the read-only document a cleaner, more professional appearance. I make it a habit to never display fields rendered by controls (ie dialog lists, radio buttons, date/time controls) in read mode, but instead to use plain text computed for display (or computed text) to render them.
Yes, that’s also a solution, but the form has to have the same look filled or not filled in. That’s what the boss wants …
Bram,
I know the feeling! What the boss wants, the boss wants…
