Is their a way (LS)
In a Lotuscript agent I seem to remember a way to get the value of a field on a doc using a variable holding the field name.
Example
TheField = “Subject1”
now using the variable TheField can I get the value of the field called Subject1 from the doc?
Subject: is their a way (LS)
doc.getItemValue(TheField) should do it
HTH
kiers
Subject: RE: is their a way (LS)
Thanks worked fine.
