Is roaming still an issue with 8.0.1?
I know I have seen threads about this and there were links to the IBM site that says it, but just to confirm that Roaming is still an issue with 8.0.1 on the standard client? Just want to make sure the data that is out there from last August is still valid.
Subject: roaming of the entrie Notes Standard Client, including the eclipse pieces, is coming in 8.5
Subject: Does roaming really not work in 8.0.1 standard client?
Documentation says:
Roaming is supported on Domino Server in 8.0.1
Roaming is supported on basic Notes client in 8.0.1
Roaming is not supported on standard Notes client in 8.0.1
Full roaming (with new features) will be supported in 8.5
However, no one, including IBM, has been able to tell me specifically what does not work on the standard client roaming in 8.0.1. I’ve got it running for a few users and it seems to work fine.
Subject: none of the eclipse pieces roam
such as sametime settings, anything in the sidebar, toolbar, extended preferences, etc. There is quite a bit. 8.5 seems to fix most of the things that need to roam …
