Is possible encrypt a text using DES method in lotusscript or @formula?
I need encrypt a text using DES method, in lotusscript or @formula, that is possible?
Somewhere can put an example code?
thanks
Subject: is possible encrypt a text using DES method in lotusscript or @formula?
Hi
If your are willing to use a Java agent is is fairly easy to encrypt a string with DES:
Here is an example from the Java Alamanac book which you almost can copy paste to an agent:
brgds Jesper Kiaer
http://www.jezzper.com
http://www.exampledepot.com/egs/javax.crypto/PassKey.html
public class DesEncrypter {
    Cipher ecipher;
    Cipher dcipher;
    // 8-byte Salt
    byte[] salt = {
        (byte)0xA9, (byte)0x9B, (byte)0xC8, (byte)0x32,
        (byte)0x56, (byte)0x35, (byte)0xE3, (byte)0x03
    // Iteration count
    int iterationCount = 19;
    DesEncrypter(String passPhrase) {
        try {
            // Create the key
            KeySpec keySpec = new PBEKeySpec(passPhrase.toCharArray(), salt, iterationCount);
            SecretKey key = SecretKeyFactory.getInstance(
                "PBEWithMD5AndDES").generateSecret(keySpec);
            ecipher = Cipher.getInstance(key.getAlgorithm());
            dcipher = Cipher.getInstance(key.getAlgorithm());
            // Prepare the parameter to the ciphers
            AlgorithmParameterSpec paramSpec = new PBEParameterSpec(salt, iterationCount);
            // Create the ciphers
            ecipher.init(Cipher.ENCRYPT_MODE, key, paramSpec);
            dcipher.init(Cipher.DECRYPT_MODE, key, paramSpec);
        } catch (java.security.InvalidAlgorithmParameterException e) {
        } catch (java.security.spec.InvalidKeySpecException e) {
        } catch (javax.crypto.NoSuchPaddingException e) {
        } catch (java.security.NoSuchAlgorithmException e) {
        } catch (java.security.InvalidKeyException e) {
    public String encrypt(String str) {
        try {
            // Encode the string into bytes using utf-8
            byte[] utf8 = str.getBytes("UTF8");
            // Encrypt
            byte[] enc = ecipher.doFinal(utf8);
            // Encode bytes to base64 to get a string
            return new sun.misc.BASE64Encoder().encode(enc);
        } catch (javax.crypto.BadPaddingException e) {
        } catch (IllegalBlockSizeException e) {
        } catch (UnsupportedEncodingException e) {
        } catch (java.io.IOException e) {
        return null;
    public String decrypt(String str) {
        try {
            // Decode base64 to get bytes
            byte[] dec = new sun.misc.BASE64Decoder().decodeBuffer(str);
            // Decrypt
            byte[] utf8 = dcipher.doFinal(dec);
            // Decode using utf-8
            return new String(utf8, "UTF8");
        return null;
// Here is an example that uses the class
try {
    // Create encrypter/decrypter class
    DesEncrypter encrypter = new DesEncrypter("My Pass Phrase!");
    // Encrypt
    String encrypted = encrypter.encrypt("Don't tell anybody!");
    // Decrypt
    String decrypted = encrypter.decrypt(encrypted);
} catch (Exception e) {
