Is it possible to read a Data Area on a DB2 platform (on iSeries) using the Lotusscript lsx libraries?
I have successfully connected to a table on the DB2 platform, however, I am told that a Data Area is not really a table.
They use a Data Area to write to when a job ends to control if it’s safe to run the next job. They’d like to implement the same type of control, which means I need to read the Data Area to check the posted message (which is only text).
It resides in the same library as the other table I’m connecting to and the username used is unrestricted in that library, but when I try to read the DataArea, I get a “Metadata object ‘FORECAST’ does not exist” error.
Here’s the code I used (I know it’s sloppy, it’s test code and I’m quite new to the lsx object model)
On Error Goto Handler
Dim agentLog As New NotesLog("Agent log")
Call agentLog.OpenAgentLog
Call agentLog.LogAction("Start Import procedure")
Dim session As New LCSession
Dim ns As New NotesSession
Dim ndb As notesDatabase
Set ndb = ns.CurrentDatabase
session.ClearStatus
Dim src As New LCConnection ("db2")
src.Database = "********"
src.UserID = "*****"
src.Password = "******"
src.Connect
Call agentLog.LogAction("Declare fields")
Dim keys As New LCFieldList
Dim datarea As New LCField (LCTYPE_TEXT, 1)
Dim field As LCField
src.Metadata = "LIBNAME.FORECAST"
Set field = Nothing
Dim fields As New LCFieldList
Dim count As Integer
count=src.Select (Nothing, 1,fields)
Print count
If count = 0 Then
	Print "The resultset is empty"
Else
	Print "There are " & count & " records which match the selection criteria."
Dim counter As Integer
count =  src.Fetch (fields, 1, 1)
While count <> 0
	Set datarea =  fields.GetField(1)
	Dim nd As New NotesDocument(ndb)
	nd.Form = "DataArea"
	nd.DataArea = datarea.text(0)
	Call nd.Save(True, False)
	counter = counter + 1
Wend
Print "     record #" & Cstr(counter)
Call agentLog.LogAction("Done running agent")
Call agentLog.Close
Exit Sub
Handler:
If (Session.Status <> LCSUCCESS) Then
	Print session.GetStatusText
Else
	Print " The following LotusScript Error has occurred" & Error$ & "in object: " & Lsi_info(2)
Call agentLog.LogAction("Agent terminated abnormally.")
Call agentLog.Close
Subject: Is it possible to read a Data Area on a DB2 platform (on iSeries) using the Lotusscript lsx libraries?
there is another way, use a stored procedure.
http://publib.boulder.ibm.com/iseries/v5r2/ic2924/index.htm?info/sqlp/rbafymst02.htm
with a stored procedure of external type, your collegue can write a program in any HLL such as Cobol or RPG or whatever he likes to read the data area and pass back the fields as output parameters.
the stored procedure needs to be registered in the database via iseries navigator or the create procedure SQL command.
I don’t know how, but I do know that you can call a stored procedure from LS lsx and receive the fields returned as output parameters.
no java and no modification to existing programs
It’s correct. A data area is not a table at all. Consider it an object that contains one text string. Trying to access it like you do will be refused by the operating system.
I never used it myself, but IBM has a Java based toolbox that can be used to access different kinds of objects on iSeries. One of the supported objects is a Data area.
You can find information on the toolbox here :
http://www-1.ibm.com/servers/eserver/iseries/toolbox/overview.htm#what
An easy workaround would be that the application that writes to the data area, writes to a database file that contains one record. Changing the application like that would only take a few minutes
Subject: RE: Is it possible to read a Data Area on a DB2 platform (on iSeries) using the Lotusscript lsx libraries?
Thank you for taking time to write your answer.
I definately want to avoid combining Java in this … it will be complex enough already :slight_smile:
I will ask the programmer to modify the programs to accomodate writing to a table with only one row like you suggested.
Luc
