Hello everyone…
Using iMap on your iPhone with your Lotus account works fine for simple mail management.
But since version 2.x of the iPhone firmware, Apple has introduced a bug.
Since I’m a apple iphone customer, I’m not to be believed as is usual with Apple.
Problem.
If you delete a message from your mail box with the iPhone, the message is copied to the “deleted message” folder (as it should), but the message still remains in the inbox. This only started with the firmware 2.x upgrades.
I’ve created a script to fix that, but would like to know if a view exists or not.
ie… set view = db.GetView (“ViewName”)
if view ISNull then exit else…
How would you do this?
Anyway here is my current interation of this script for all who wish to use it or change as they see fit.
Set it to run when document is modified in the deleted messages folder or on a 15 min schedule… (your choice).
Sub Initialize
Dim s As New NotesSession
Dim db As NotesDatabase
Dim view1 As NotesView
Dim view2 As NotesView
Dim doc1 As NotesDocument
Dim doc2 As NotesDocument
Dim tempDoc As NotesDocument
Dim item1 As NotesItem
Dim item2 As NotesItem
Dim sub_text1 As String
Dim sub_text2 As String
Set db = s.CurrentDatabase
Set view1 = db.GetView ("Deleted Messages")
Set doc1 = view1.GetFirstDocument
While Not ( doc1 Is Nothing )
Set tempDoc = doc1
Set item1 = doc1.getFirstItem ( "subject" )
sub_text1 = item1.text
Set view2 = db.GetView ("($Inbox)")
Set doc2 = view2.GetLastDocument
While Not (doc2 Is Nothing)
Set tempDoc2 = doc2
Set item2 = doc2.GetFirstItem ("subject")
sub_text2 = item2.text
If sub_text2=sub_text1 Then
Call tempDoc2.Remove ( True )
foundit = 1
Goto firstWhile
Set doc2 = view2.GetPrevDocument ( doc2 )
Wend
firstWhile:
Set doc1=view1.GetNextDocument ( doc1 )
If foundit = 1 Then
Call tempdoc.remove ( True )
foundit = 0
Wend
If there is a more effecient way of doing this, I would be all ears…
thanks
Brett
