Inview edit validation problem
Hi Everybody,A document with a text field x has a value 8.
This is selected in a view. There is validation in the the script to trap invalid values.
When view column is edited in notes and the value is modified to 8&. The Invalid value message is shown desired but thereafter notes
throws an error message “Error validating column value”.
Is there any solution to this problem ? I want to avoid this prompt message, but display my invalid message while validating
Ankit
The inview edit script is as below
Sub Inviewedit(Source As Notesuiview, Requesttype As Integer, Colprogname As Variant, Columnvalue As Variant, Continue As Variant)
Const QUERY_REQUEST = 1
Const VALIDATE_REQUEST = 2
Const SAVE_REQUEST = 3
Const NEWENTRY_REQUEST = 4
REM Define variables
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim caret As String
REM Get the CaretNoteID - exit if it does not point at a document
caret = Source.CaretNoteID
If caret = “0” Then Exit Sub
REM Get the current database and document
Set db = Source.View.Parent
Set doc = db.GetDocumentByID(caret)
REM Select the request type
Select Case Requesttype
Case QUERY_REQUEST
REM Reserved - do not use in Release 6.0
Case VALIDATE_REQUEST
Msgbox "Columnvalue(0) "&Columnvalue(0)
REM Cause validation error if user tries to exit column with no value
If Instr(Columnvalue(0)," ") Then
Continue = False
Msgbox “with space”
If Instr(Columnvalue(0),“&”) Then
Continue = False
Msgbox “with&”
Exit Sub
Case SAVE_REQUEST
REM Write the edited column view entries back to the document
For i = 0 To Ubound(Colprogname)
Call doc.ReplaceItemValue(Colprogname(i), Columnvalue(i))
Next
REM Save(force, createResponse, markRead)
Call doc.Save(True, True, True)
Case NEWENTRY_REQUEST
REM Create document and create “Form” item
REM Write column values to the new document
Set doc = New NotesDocument(db)
Call doc.ReplaceItemValue(“Form”, “Test”)
Next
End Select
Subject: Inview edit validation problem
Get the error number for that error (using a Messagebox or a Print statement) and than write an error handler specifically for this error number that does nothing.
Subject: RE: Inview edit validation problem
The error that is shown is a message box with title ‘IBM Lotus Notes’ and message as ‘Error validating column value’. I am not able to find the error number. This occurs due to the statement ‘continue = False’ in validation portion. If this statement isn’t included, then the save event is automatically triggered and the document is saved with invalid entry which shouldn’t occur. Need your help.
The error text wont help you.
Use the Err function to return the error number. Once you know this error number, you can write an On Error statement specifically for this error.
Tried debugging the code using the Err function, the error message is displayed after the end sub(last statement) of the inview edit event and so doesnt displays the error number, it comes out of all the select cases, goes to the error handler (next statement) just shows error number 0, then end sub and then shows the error message which i want to avoid.
The help menu says ‘Set this parameter(continue) to False to stop processing and generate an error message’
Dim caret As String
Case QUERY_REQUEST
exit sub
Continue = False
Msgbox “with space”
Continue = False
Msgbox “with&”
On Error GoTo Errhandle
'doesnt goes to errhandle
'exit sub
Case SAVE_REQUEST
Next
exit sub
Next
exit sub
End Select
Errhandle:
MessageBox “Error” & Str(Err) & ": " & Error$
'show error 0
Exit Sub
'displays error message after control to this statement
Without checking any detail yet, your code is currently missing an Exit Sub after the End Select. Right now, your error handler is always executed, even if no error occurs.
I have corrected that, but still it doesnt works. The previous error message still persists
Dim uidoc As notesuidocument
Dim edoc As notesdocument
'Set edoc=uidoc.document
Dim caret As String
'Dim txt1,txt2,txt3 As String
'Dim chk As Integer
Dim item As NotesItem
If caret = "0" Then Exit Sub
'On Error Goto Errhandle
Case QUERY_REQUEST
Continue = False
Msgbox “with space”
Continue = False
Msgbox “with&”
'it doesnt goes to errhandle
Case SAVE_REQUEST
	For i = 0 To Ubound(Colprogname) Step 1
	Next
	Call doc.ReplaceItemValue("Form", "Main")
	Next
Case Else
End Select
Exit Sub
Errhandle:
’ Use the Err function to return the error number and
’ the Error$ function to return the error message.
Messagebox "Error" & Str(Err) & ": " & Error$
Subject: work around
good old buggy notes!I am having the same problem.
This work around from Toby may help.
(disadvantage: user looses the focus and his entries)
Have a look into
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/1af83491ef694de385256d88006330cd?OpenDocument
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/c4efbd3607e7541985256d8800630d9a?OpenDocument
Thank you, Toby!
