Intellisync Notes-IPAQ Calendar Problem
Part way thru calendar sync using IPAQ Outlook 2003-Intellisync-Notes 6.5.2 Intellisync and Notes close after error message "NSD is Running Saving to file C: …logI had some repeat meetins on IPAQ but have deleted them, problem is still there. 124 items appear to be sync’d before closure, but I cannot see any changes to Notes calendar
Subject: Intellisync Notes-IPAQ Calendar Problem
Possible resolution by cleaning up the mail file:1. Locate and remove rep save conflicts
  1. Search all documents and meetings view for corrutped entries (will lack subject line)
  2. purge deletion stubs
  3. fixup / updall / replace design / compact
Try again. If it still fails, then repeat steps 1 thru 4, hard reset the PDA and do a one way sync to the PDA from Notes. You might want to discourage by-directional syncing of the calendar with PDA’s. The error rate is very high for users who utilize group calendaring.
Hope this helps,
Kristin
