Is there any way to allow a user to select an input from a list of options (like ticking a radio button) from within a script button?
I would like a user to be able to select a month from the list of 12 months
TIA
TIA
Subject: Input Selection using Lotus Script
You can use the prompt method from notesuiworkspace.
Subject: Input Selection using Lotus Script - solved
Thanks to you both
The workspace.prompt worked just as I wanted
Cheers
Sure. Look at the Prompt method of the NotesUIWorkspace class. In this case, you’d be looking for the PROMPT_OKCANCELLIST version.
