Hi All I am having a very small issue in Inputbox,I am accepting Employee Code using inputbox,it’s working fine,now i need if some one clicks on cancel it should come out of the form,i tried n no of logic but all in vain.
peace of code
ecode1=Inputbox(“enter the emp code”)
Subject: Input Box-Little issue
if ecode1 = “” then
Using the notesUIWorkspace.Prompt method gives you more options.Using the PROMPT_OKCANCELEDIT option you get a behaviour very similar to the Inputbox.
To know if Cancel was clicked, you’d use something like this:
Dim vResponse As Variant
Dim strEmployeeCode As String
vResponse = ws.Prompt(PROMPT_OKCANCELEDIT, “Employee Code”, “Enter Employee Code”)
If IsEmpty(vResponse) Then
'-- Cancel clicked.
'-- Do something
If IsArray(vResponse) Then
strEmployeeCode = vResponse(0)
Else
'-- Do something with the Employee Code.
Hope this helps
ken@noteshound.com
