iNotes Time Problem
From the notes client the Date/Time stamp are correct whether you look at it from the sent view or the inbox or even open up the email.
However, in iNotes, the date/time are correct if looking at sent or inbox, but if you open the email, it is off by 5 hours.
Any help would be appreciated.
Subject: SOLUTION: iNotes Time Problem
Doing the forms6 update for DST solved this problem.
Subject: iNotes Time Problem
check you clock on PC you using iNotes most likely you time is off 5 hours
Tim
Subject: RE: iNotes Time Problem
The time on the PC is not incorrect. A user called me complaining of this issue and I could reproduce the problem from my own PC. When I checked the time on the Notes client version of that same account, the time showed correctly. Looking further, the preferences in the iNotes client were set to GMT. Any idea how this would get changed? It seems like it may have changed for all databases on the server?
