Inotes (dwa) problem when removing language
Hello.
We have installed inotes on our 8.5 server. We also installed swedish language pack on the server. Now our organisation has said that all information shall be in English, including notes and INotes. So we have unistalled the language pack only keeping the English Language. This has worked fine except for when you start inotes.
When we start inotes we get the swedish translation of “Loading IBM INotes”, and some of the email buttons are also translated. I have tried to replace the design for the mail file, forms85.nsf but it hasn’t helped.
Can anyone assist me in finding where out how i can remove this problem.
Philip
Subject: set IE settings
try to set default Language in InternetExplorer properties. (set english as first and if you need swedish - as second…)
the same you can do if you use FF or any other.
Hello.
Yes, you can set the ie setting and this will display the other language, but that isn’t the problem. We want all users to receive the english setting, whitout having to change there ie (or ff) settings.
Before we installed the swedish language pack all users had the english settings, and after we uninstalled the swedish language pack we want all users to have the english settings again. But somehow the swedish settings are still there.
Thanks for your help.
/Philip
Subject: forms85
I see,than you can try have a look inside of design “forms85.nsf” under “shared elements/subforms” and here try to find subform with “swedish” language.
probably there should be twice “custom_js_lite” one with EN and one with swedish lang.
Subject: forms85
Hello.
I have checked the subforms, and we only have one custom_js_lite. We have teamstudio configurator installed and i have used it to search for the swedish words, but the search returns nothing both for design and documents.
Can there be another place where this is stored, any suggestions is appreciated.
/Philip
