iNotes authentification works, same user with pop3 not work
Hello!
On the same server, with the same user/password, I’m able to open an iNotes web access session but cannot open a POP3 session
what’s wrong
Thanks!
Subject: the log of my pop3 session
10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Run: No Outstanding IO
10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Init state
10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Greeting state 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Send(1): Queue send buffer, Status = 0000h
10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Authenticate User state 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Exit QRecvCommand = TRUE 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Exit GetCommand Results = FALSE 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Authenticate User state 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] GetCommandLine Exit 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Exit GetCommand Results = TRUE 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Authenticate User Command Received 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] USER command 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Send(1): Queue send buffer, Status = 0000h
10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Authenticate Pass state 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Exit QRecvCommand = TRUE 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Exit GetCommand Results = FALSE 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Authenticate Pass state 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] GetCommandLine Exit 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Exit GetCommand Results = TRUE 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Authenticate Pass Command Received 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] PASS command 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000022] Send(1): Queue send buffer, Status = 0000h
10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Terminal state 10/08/2009 11:16:53 POP3 Server: [896613:10951:00008-00000023] Exit StateTerminal
Subject: password
Did you change the password recently?
Run this command ‘show nlcache reset’
See if that helps.
Subject: session from a telnet on port 110
This is a telnet session to my server
+OK Lotus Notes POP3 server version Release 8.0.2FP2 ready on Domfppq2/DMZFPPQ.
USER cabelanger
+OK cabelanger, your papers please.
PASS xxxxxxxxxx
-ERR Error. The system was unable to log cabelanger in.
Subject: email
Try with the email address, or a different username.
I suspect it could be something related to the login security (Fewer variations with more security)
Also, do you have Directory Assistance?
Subject: e-mail address seem’s to works
Using the e-mail address as the username solve the problem and yes I use a directory assistance.
I’m not sure why it’s working, but it is.
Thanks to you!
Subject: DA
You re welcome!
I asusme it’s something about the DA and it’s finding duplicates.
If that’s enough for you, use it that way. Othersise, I would start by disabling DA and trying again. But it could be something around that.
