Including Button in email body by using Lotus Script?
I found this previous thread stating it wasn’t possible ==>
Has this possibly changed with Lotus Notes 7, or someone has found a way to do it?
I’ve done the appending of a button from another rich text document before, but with my latest project I would like to modify the code of the button.
Thanks for the help.
Subject: Including Button in email body by using Lotus Script?
i have a button in a profile doc, that we use to send out in emails. i just create an email and attach that richtext field from the profile like below. i can just pull up the profile anytime and pull out the button, modify the code, then place it back, then save in the richtext field on the profile.
jason
jasonsmith@columbusga.org
Dim rtitem As notesrichtextitem
Dim profiledoc As notesdocument
Dim profile_button As notesrichtextitem
Set profiledoc = db.getprofiledocument(“Profile”)
Set profile_button = profiledoc.getfirstitem(“button”)
Call rtitem.appendrtitem(profile_button)
Subject: RE: Including Button in email body by using Lotus Script?
Thanks Jason for the reply. I too have done the appending of a button from another document. I was just hoping that version 7 had added something.
However, I am having another weird problem when appending my button, any ideas? ==>
