[IncludeDoclink] Problem
Hi, Im trying to send a doclink but for some reason it shows the path of the Doclink and not the actual doclink in the email. Any help is greatly appreciated. The dB has a default view. Sending mail to Notes client. Address from NAB.heres my code:
@MailSend(SendTo; “”; “”; ToSubject; ToRemark; “”;[IncludeDoclink]);
Thanks.
heres what I get in the email :
(Document link: Database ‘name of the dB’. View ‘Name of the view’, Document ‘Name of the doc’)
Subject: [IncludeDoclink] Problem.
That is outbound mail conversion. If you are sending to a Notes user and using an internet mail address, the server will convert the message if it doesn’t recognize the name, and the client will convert if the Location document specifies that mail addressed to internet addresses should be sent directly to the internet. If it’s at all practical to do so, use Notes names rather than email addresses when sending.
Subject: RE: [IncludeDoclink] Problem.
Stan
Thanks for the immediate response. The mail is sent to Individuals in a Notes User group and it is picked from the NAB. So Im assuming it is a Notes name and not an Internet email address. Im not sure if theres any server side setting I should b aware of.
LL
Its working now. The change required was in names.nsf, Basic tab, “Format preference for Incoming mail” must be set to Keep in senders format.
