hcl-bot
1
I have a saved document already using the form Purchase Item Entry.Only one field is left without being filled.
I want to get the old document and enter the field value.
I have a 'rder number’and ‘urchase order number’.
Now should I get the document from its view and then re-edit it?
Please give an easy and an effective way to solve this problem…
Thanks in advance.
Anju Deshmukh
hcl-bot
2
Subject: RE: In dire need for help in lotus script
Anju
To confirm I understand your request correctly:
You wish to populate a field on the current form (formA) with a value from a previously created form (formB)!?
If this is the case, you need to ‘get’ formB using a unique identifier (perhaps this could be the order or purchase order number or NoteID etc?)
Set formA = db.CurrentDocument
Set formB = view.GetDocumentBykey(formA.UniqueIdentifier(0))
Once you get a handle on formB, you can then access the values of it. All you then need to do is set the value on formA with the value of formB
requiredvalue = formB.FieldName
formA.missingvalue = requiredvalue
HTH
Kendy
