Importing XML data posted on URL using asp into Lotus Domino using Servlets
Hi All,Please look into the below given issue.
I am posting the data from asp to Lotus domino using XML.
Can some one help me in fetching the data from XML thru servlets. The client’s application is built using asp. They are asking for a URL and XML template. On click of Submit button of their application the URL will be triggeredand data will be posted using POST method. How can it be feasible to collect the data from that URL using Java Servlets in Lotus Domino.
Any help will be highly appreciated.
Subject: importing XML data posted on URL using asp into Lotus Domino using Servlets
ASP:xmlstr="xmlstr= ur xmal>
in servlet
get request of “xmlstr”
