HI ALL
How to import data from excel sheet to notes using inbuilt method
HI ALL
Subject: importing problem
'Try with the below code Set Excel = CreateObject(“Excel.Application”)
Excel.Visible = False
Excel.Workbooks.Open(FilePath)
Set ExcelWorkbook = Excel.ActiveWorkbook
Set ExcelSheet = ExcelWorkbook.ActiveSheet
Set ExcelCells = ExcelSheet.Cells
Set view = db.GetView("allByRefKeysPP")
Set doc=view.GetDocumentByKey(refkey,True)
'Importing the financials from the Excel sheet to Project Parameters document
r=13 ---> row
c=5 ---> Column
%rem
arrOfFields(i) – > this is your field name.
ExcelCells( r,c).Value — > In the Excel Value
%end rem
Call doc.ReplaceItemValue(arrOfFields(i),ExcelCells( r,c).Value)
Subject: RE: importing problem
CAN YOU SEND FULL CODE FOR THIS
Subject: Free Import Tool
We have a Lotus Notes / Domino import utility you can freely download from our website at:Import Utility for Notes
It automatically handles importing from Excel, CSV, Tab, Outlook and other file formats.
Lots of other great features too such as duplicate handling, document updates, etc.
Hope it helps.
Alex
reddy m, I notice you post a lot of questions in this forum. Do you ever use the Search on this forum to see if your questions have already been asked by someone else?
For example, there are hundreds of threads on importing data from excel.
Also, the people who help out here usually prefer it if you at least have a go at doing these things first, rather than posting up a question for every thing you need to do and just asking for code straight away. Search the forums, read the Designer help, have a go at the code for yourself; then if you get stuck post a question along with whatever code you have written.
Great post… He’s flooding (spamming I would call it) the forum and it seems like he never actually reads the reply’s (If there’s no code in it) let alone thank’s people who help him…
Hope it helps.
Alex
Good post David
Nothing switches people’s desire to help off quicker than the sight of “PLEASE POST FULL CODE”
Mike
