Hello,
I have used CreateDXLExporter to export a notesdocument to an XML file. The document contains a body field with rich text data such as pictures…
After the content of some fields has been changed in the xml file, I want to import certain data of the file back into my body field.
My problem is that the data of the body field, is devided over serveral tags. I have several tags, one . I would like to put all info from the body tag into the body field of the notesdocument.
My second problem is that pictures are encoded into text and I have to decode it again.
It is easy to import the whole document again, but I have troubles importing only the rich text content.
Hopefully someone can help me…
20071120T130327,97+01
Das ist ein Test des Rich Text Field.
Text content
Part of my code I used to import the whole document:
strUNID = GetUNID(session, stream)
Set docOrig = db.GetDocumentByUNID(strUNID)
Dim importer As NotesDXLImporter
Set importer = session.CreateDXLImporter(stream, db)
importer.DocumentImportOption = DXLIMPORTOPTION_CREATE
Call importer.Process
Function GetUNID(session As notessession, stream As notesstream) As String
Dim strUNID As String
Set domParser=session.CreateDOMParser(Stream)
domParser.Process
Set rootElement = domParser.Document.DocumentElement
Set docList = rootElement.GetElementsByTagName ("noteinfo")
If docList.NumberOfEntries = 0 Then
Messagebox "No <document> element nodes in file", , "Error"
Exit Function
Else
For i = 1 To doclist.NumberOfEntries
Set enode = docList.GetItem(i)
getUNID = enode.GetAttribute("unid")
Next
