Hi All,
I have an excel file and my first column is First Names and 2nd column is Last Name,
I need to create a document that has Name in the form as Abbreviated Name (How can I convert FirstName and lastName as 2 separate columns into an Abbreviated name …)
I guess I will have to do a lookup to the Address Book…
Please help , how to do a look up to the address book and get the abbreviated Name
here is my part of the code
Dim db As NotesDatabase
Dim Doc As NotesDocument
Dim file As String
Dim username As NotesName
Dim xlsheet As Variant
Dim date1 As NotesDateTime
Set db = Session.currentdatabase
date1.LSLocalTime = Now
Set xlApp = CreateObject("Excel.application")
xlApp.Visible = False
file=Inputbox("Please enter path of the spreadsheet like" & Chr(10) &_
" C:\spreadsheet.xls", "File Path Inquiry Box", " enter path here ....")
xlApp.Workbooks.Open file
ARangeValue = xlApp.Range("A5").Value
Print " Please Wait Importing Data ....."
Dim toff, ton , vac As String
Set username = New NotesName(session.Username)
i = 4
Do Until ARangeValue = ""
i = i + 1
ARangeValue = xlApp.Range("A" & Trim(Str(i))).Value
Set doc = db.CreateDocument
doc.Form = "Appointment"
doc.Name_1 = xlApp.Range("B" & Trim(Str(i))).Value + " " + xlApp.Range("A" & Trim(Str(i))).Value
doc.CreateDate = date1.DateOnly
doc.Status = "Approved"
Call doc.save(True, False)
Loop
Call workspace.ViewRefresh
Set xlApp = Nothing
end Sub
How to dod the lookup and get the abbreviated name?
Also In my excel sheet after the 2nd column , I have Month Date Calendar and I need to bring every cell for the each month and data in those cells For eg Cell Range AX to BN is for the Month of April and AX value is 14 and cell BN value is 30
(14 and 30 are the dates for the Month of April 2008)
How can I programmatically get these values …
and besides every Firstname and Lastname I have for eg : ac ac cell AX is filled as vacation to AZ as Vacation
For next row Name: XYZ : cell BA is Training to BB as training and so on …
How can I get it programmatically every month range into the document
My form has Start Date and End Date (The Form Start Date should have if the person’s scheduled for a vacation or training or etc and end date should be the date when it is ended.
Please help,
Thanks in advance
ac ac
