context it shows error message “Invalid or Non-Existent document” for all new messages. When I check the server side ( there is no attempt to retrieve that message or any other command sent from client). After I close the database and I open it again , everything is OK. Does anyone experience the same problem ?
I have got exactly the same problem by retrieving some mails from a voicemail account, and I have not found yet any solution for this. Did you hear about anything about it? (a new IMAP client for Lotus Notes or something to configure with it?)
It seems that the Lotus Support and development team did not consider this as an important bug. So this bug exists in every version of the Notes IMAP client 6.0.X and 6.5.X. It will not be corrected for the next version of Notes 6. But it works fine with R5 Notes Client, so you can always reinstall it. Otherwise, just try an other client like thunderbird.
This bug might be corrected for the version 7 of Notes, but the support did not seem to be convinced about it.
