Ignore words containing numbers does not work (Bug?)
There is an option in spell check that when you click “Spelling Options” it allows you to selct “Ignore words containing numbers” This does not work. If you select it and then go through the spell check it still checks words with numbers. It also always defaults to be not selected. Is this a bug??
