Ignore post, problem solved
The agent I am running has a refreshwindow command that is overriding a print statement that is suppose show up when the agent is called. When I click on the status bar, it shows that the print command worked, however it does not stay on the bar (in other words, after the entire command is complete, the bar is clear; I need my print statement to be the last thing showing). The code is below If you need a reference to what the code does, refer to a post called: @Sort in Lotus Script
Thanks for any help ahead of time.
Code behind action button:
Sub Initialize
Dim s As New NotesSession
Dim db As NotesDatabase
Dim agent As NotesAgent
Set db = s.CurrentDatabase
Set agent = db.GetAgent("solution_all complete")
If agent.Run = 0 Then
	Print "Agent ran",, "Success"
Else
	Print "Agent did not run",, "Failure"
Agent Code:
Sub Initialize
Dim uiview As NotesUIView
Dim view As NotesView
Dim formula As String
Dim formula2 As String
formula = "SELECT @All"
Set uiview = ws.CurrentView
Set view = uiview.View
view.SelectionFormula = formula
Call ws.ReloadWindow( )
formula2 = "SELECT s_cdate != ''"
view.SelectionFormula = formula2
Subject: Problem with Print statement when runnning agent
Did you hit up arrow? I am guessing that it is in the history of messages that went to the bar.
Subject: RE: Problem with Print statement when runnning agent
It is in the history; however, I need it to be displayed on the status bar, so people won’t have to click that button.
