ID Vault, how does it work?
Have just set up ID Vault on Domino 8.5.I created a policy document and added some testusers. The id’s uploads just fine. I tried to reset a password. Seems to work like a charm.
My question is; If I change user on a Notes client, I still have to browse for my ID?
Is it only the password reset that is the feature?
Subject: Good Question
Yes, when you use the Security / Switch ID menu item you must still browse for an existing ID file.
It is a very reasonable new feature request to add a menu item which would be something like “Switch to a user in the ID vault”. We will consider this for a future release.
Subject: No ID files
Ok. That would be something to aim for. A timesaver for us domino administrators and less confusion for users.
