Subject: You need to consider UIDoc/Doc and Summary/Non Summary fields
Notes stores data on document
there may be many items on that document containg data of diffrent type(Number text etc)
when you use the propertied mechanism you are seeing directly to the items on that document
however and whenver they were created
Notes displays a document using a form (which one depends on circumstances) but there is always a form
a form has fields on it …
if you get the UIDOc handle and use FieldGetText( “Fieldname”) and there is NO corresponding field on the form
it will FAIL as you’ve found
This is true even if there is an ITEM on the document with the required name
so all you need to do is IGNORE the form (as accessed via the UIDOC)
and use the Document to access the items
Try something like this
(code not compiled or tested … just use it as a guide)
Dim uidoc As NotesUIDocument
Dim composed As String
Dim doc as NotesDocument
Dim itm as NotesItem
Dim myfield As String
myfield=“VerificationResult”
Set uidoc = workspace.CurrentDocument
set doc = uidoc.document
set itm = doc.GetFirstItem( myfield )
if Not itm is Nothing then
composed = itm.Text
end if
as to the Field flags “SUMMARY”
thats a bit complicated.
basically an item without a SUMMARY flag cannot be used in a view column
In normal circumstances only RICH Text items are non-Summary
other items whether Text, or Number or Time are nrmally summary
however even these types can be non summary
especially if created in complex circumstances e.g. a mail router fromoutside domino
However you can still get at the content in Lotus Script as above
Note: this extract from DEsigner Help may show a bit more about summary
ISSUMMARY PROPERTY
Read-write. Indicates whether an item contains summary or non-summary data.
Defined in
NotesItem
Data type
Boolean
Syntax
To get: flag = notesItem.IsSummary
To set: notesItem.IsSummary = flag
Legal values
True indicates that the item contains summary data.
False indicates that the item contains non-summary data.
Usage
Items are flagged as containing summary or non-summary data. Summary data can appear in views and folders; non-summary data cannot. In general, items created through the UI are tagged as non-summary if they contain rich text or are very long.
When you create a new item using New, the IsSummary property for the item is False. If you want the item to appear in views and folders, you must explicitly change its IsSummary property to True.
When you create a new item using AppendItemValue in NotesDocument, ReplaceItemValue in NotesDocument, or the extended class syntax, the IsSummary property for the item is True. If you don’t want the item to appear in views and folders, you must change its IsSummary property to False.
You can enable or disable the appearance of an existing item in views and folders by changing its IsSummary property.
An item whose IsSummary property is True may not appear as expected in views and folders if the data is not suitable. For example, a rich text item whose IsSummary property is True generally appears as a question mark.
