I need help but don't know exactly what to ask for
I recently went to a R6 launch and saw a new development feature which I liked. I now want to use if but do not know what it was called.
Basically (I hope that this makes sense) you could have a form with details on it. You could over lap those details with a region which could be draged over with more details.
Anyone know what I am getting at?
Regards
Vaughan
Subject: I need help but don’t know exactly what to ask for…
Yes, you are talking about Layers. They have been around for some time now in web development and are very helpful for doing that type of presentation. You can also use them for fields, you are not just limited to text and graphics.
I recommend that you practice with them. The setup of a multi-layer section of a form can be a little confusing the first time around.
Or consider taking the ND420 class to get a decent introduction to how to use them among other things.
I think you’re talking about layers (go to Create menu, Layer). I haven’t used them, but I think that’s what you mean.
Subject: RE: I need help but don’t know exactly what to ask for…
Thanks for your help!
That is exactly what I was looking for.
