HTTP POST problem: A connection with a remote socket was reset by that socket
Hello,
I’m running the following method to http post xml data:
public StringBuffer post(String xml) {
	OutputStream os = null;
	InputStream is = null;
	BufferedWriter wr = null;
	BufferedReader rd = null;
	StringBuffer response = null;
	try {
		if (_addr == null)
			_addr = InetAddress.getByName(hostname);
		if (_sock == null)
			_sock = new Socket(_addr, port);
		os = _sock.getOutputStream();
		is = _sock.getInputStream();
		wr = new BufferedWriter(new OutputStreamWriter(os, encoding));
		wr.write("POST " + path + " HTTP/1.1\r\n");
		wr.write("Host: " + hostname + "\r\n");
		wr.write("Content-Length: " + xml.length() + "\r\n");
		wr.write("Content-Type: application/soap+xml; charset=\""
				+ encoding.toLowerCase() + "\"\r\n");
		wr.write("\r\n");
		wr.write(xml);
		wr.flush();
		rd = new BufferedReader(new InputStreamReader(is, encoding));
		if (rd != null) {
			response = new StringBuffer();
			String line;
			while ((line = rd.readLine()) != null)
				response.append(line + "\r\n");
		wr.close();
		os.close();
		rd.close();
		is.close();
	} catch (Exception e) {
		try {
			if (wr != null)
				wr.close();
			if (os != null)
				os.close();
			if (rd != null)
				rd.close();
			if (is != null)
				is.close();
			if (_sock != null)
				_sock.close();
		} catch (Exception ignore) {
		e.printStackTrace();
	return response;
When I run this code against various test services from SoapClient.com it works just fine. But when I use a service from a Microsoft BizTalk server the service in question is executed ok and headers along with HTTP/1.1 200 OK are received back but the SOAP body is not… Instead, it hangs waiting until domino log says: “A connection with a remote socket was reset by that socket” (etc.).
There’s got to be something in my code I’m overlooking. Can I lend you eyes and brains for a minute?
TIA,
Jan Sandholm
Subject: HTTP POST problem: A connection with a remote socket was reset by that socket
Solved. Seems like sending request with HTTP/1.0 instead of HTTP/1.1 solves the problem. Something problematic in the BizTalk server.
