HTTP Header Order - Invalid POST Request
Certain POST Requests to a domino server cause an internal server error 500.
Looking into detail of the http stream shows, that the domino is not able to interpret the full http header comming from the client.
As a workaround it helps to place the host header tag on the second position in the http header section. Doing so by a small perl script which significantly decreases perfomance.
Will there be a solution?
stefan
