hcl-bot
1
Hello, It was failed runung with the LotusScript below,
string=Evaluate(|@Right(picklist,“,”)+" " +@Left(picklist,“,”)|)
Would you please tell me how to revise it?
Actually, I would like to use LotusScript instead of @right(str1;“,”)+" “+@left(str1;”,")
Thanks,
Linda
hcl-bot
2
Subject: how to write LotusScript instead @right(string;“,”)
Linda,
Do you mean something like this
pos% = instr ( 1, picklist, “,” )
if pos% > 0 then
string = right$ ( picklist, len ( picklist ) - pos% ) & " " & left$ ( picklist, pos% - 1 )
I sometimes mess up whether it’s pos% - 1 or + 1, etc., so check my math, but that’s the idea.
regards,
raphael
hcl-bot
3
Subject: RE: how to write LotusScript instead @right(string;“,”)
Thanks Raphael for your responding quickly.
It works fine
Thanks a lot!
Linda
